xs650 dragbike
Looked good, shame I couldn't hear it on this computer,
How many runs did it take to set it up and get it that quick?
Here's a couple of pic's
Cowboy . . very cool. And what makes it so cool is that you are way out of the box :) 10.65 is moving for one of these engines. Do you think there's anything else left in it??
18/38,had a tach w/telltale would hit 10,000 rpm. the rev limiter has a upper limit of
9500 rpm, have to turn off after launch or hits upper limit at about 1200 ft.
Here is a clip of my 1/8 mile run. The motor is stock with a first over bore. 38mm stock carbs with larger main jet, K&N oval filters and 1 3/4 open pipes. Gearing is 17T with 42T. Easy launch since the clutch gets weak when run hard.
