I am wiring my XS650 and second guessing myself. Simple wiring, but don't want to fry something.
Quick run down-
Kick only
Headlight/tail light (no signals)
High output single black coil (mikesxs kit)
Permanent Magnet Alternator
Pamco ignition
(Toggle on/off ignition switch) no key switch.
Question:
To run a simple on/off toggle switch to act as an ignition on/off (kill switch) since I am not running a key switch. Do I run the wires from the Pamco ignition module directly to the toggle, and from toggle down to the single coil?
Or would I go directly to coil and back to toggle switch?
I have a SPST on/off toggle with two poles. Depending on which way it is to be wired at coil, how would the red and green wires from the module connect to the toggle? Both wires on one pole and power to the other?
I am brain farting on how to power the toggle/coil.
Thanks!
Quick run down-
Kick only
Pamco ignition
Question:
Thanks!
