rptc
Just got done with an engine rebuild on my 81 xs650 special. Started it up after getting the motor back in and its running on pretty much one cylinder. It's getting spark, I checked it on the side of the motor. It's theoretically getting fuel, we sprayed ether into the carb on the weak side and no change. There's pressure out of the exhaust on that side. The valves are adjusted. Everything I've seen someone else has ran in to from my research on here and many other websites was checked and I'm still running poor on the right side. I rebuilt the carbs and replaced the ignition coil along with plugs and wires when the motor was pulled. I'm out of ideas and just want my bike to run strong again. Any ideas would be greatly appreciated.
