Welcome to the forumFirst, welcome to the forum!!!
Second, you got your belt and shoes swapped... Here, I flipped it for ya.
Third, yes... looks to be an 80SG.
What's your plans for it?
That a 63-64 Falcon in the background?
A journey of a thousand miles begins with but a first step. Off ya go.Just gave it a warm soapy bath... still have some cleaning to do but this gave me a better idea on the trouble spots.
That means the spring is not off the hook and the hook is not broken.It springs back up
Without going back through 4 pages, what's your compression issue?Still trying to troubleshoot the compression issue. Any suggestions on where to start?
When I use the kick start there is 0 resistance. A few suggestions were the spring being disconnected but the Kickstarter does spring back. Jim I think you specifically said to give it multiple kicks and let it spring back to see if something frees upWithout going back through 4 pages, what's your compression issue?
It would be very strange if the compression is gone after such a short running distance
I would try to work the clutch.
on the left side there is a Phillips Looking screw with a lock nut
i would release it . If it is to far in the engine wont turn.via the kick
So, just so we all stay on the same page terminology-wise.... you have a kick starter not working, not a compression issue. You have to spin the motor to see if you have compression... and the kicker isn't spinning it.When I use the kick start there is 0 resistance. A few suggestions were the spring being disconnected but the Kickstarter does spring back. Jim I think you specifically said to give it multiple kicks and let it spring back to see if something frees up
Try this... put the tranny in gear... first, second... doesn't matter. Now push down on the kicker. Does the rear wheel spin?
OK... makin' progress... the kicker works. Go ahead and put the tranny back in neutral. Now remove the cover Skull referenced above, kick it over and tell us if the rotor (watch the nut) spins? If it does, the clutch is engaged. If it doesn't... it's not.yes wheel spins when I put it in gear and push down the kicker.
The nut you see is the end of the crank. get a socket and longish bar and turn the nut and this will turn over the engine. If stuck you can jiggle it back and forth to help break the seize. I think it can be a more gentile way to do this. View attachment 191839
Now we're cookin'. We now know the motor's not seized and the clutch is disengaged. See the adjuster to the right of the alternator? Loosen that nut and back the screw all the way off. Hell, you can remove the screw just to make sure it's backed off enough. If you have an impact gun, that's your best bet for breakin' the nut looses.... it's likely gonna be a stubborn bugger. Now, hit the kicker and tell us if the crank (rotor) spins? Backing the adjuster off will tell us if it's just the clutch improperly adjusted or if there's a problem with the clutch itself.Removed the cover(wasn’t fun 1 screw had some good rust on it but nothing snapped or stripped. Small victory)
Kicked it over and NO the rotor didn’t spin. Used a socket and a bar, gently gave it a spin and it did move freely(as in not seized)
Excellent!! So are you sayin' initially the clutch stayed disengage and after some kicks it's now engaged?removed screw and nut(easily luckily) and gave it a few kicks, nothing.... said the hell with it and kicked it about 5 more times and WE’VE GOT MOVEMENT!!
Now we're cookin'.
