nsydyrhd
XS650 New Member
I have a 79/80 xs650. Like most mine had the typical charging system problem. I replaced the charging system with the Permanent Magnet Alternator Kit from Mikesxs. I also replace the TCI ignition with the Pamco Electronic Ignition Kit #14-0902 from Mikes as well. Everything for the most part seems to be working. Instead of only being able to ride a half an hour I can now ride a couple of hours. The problem now is after I ride and let the bike sit overnight, the next morning the battery will be deep. I have replace the battery with a Everlast AGM battery. I took this battery to an auto parts store to trickle charge and test the battery. That came back good. I can also say I let the battery set for 2 days not connected to the battery and this morning popped it back in and roar we were off. SO I'm looking for suggestions on how to run down this parasite. Should I replace the wiring harness? If so is there one I can buy that will work for my upgrades? Or is there a systematic way to track this problem down?
