chopit25
Ok so i have read alot here on this and went by the manual and even watched some youtube videos. I amlost now though. Every wire and connections ir correct, grounded well and new. Carbs are clean as new and set to factory settings. Brand new coils, points, condenser. I tried to start the bike and it seemed the timing must have been off so i checked the cam chain adjustment and it was in spec. I adjusted the valves to the manual specs. I have never had it run so i tried the static timing method by using a 12v bulb on the right point and turning the crank with a ratchet. When i spin it around it lights up way after the timing plate and no matter which way i rotate the points plate it doesnt even come close. Then the coils got really hot and shut down. I hope i didnt fry them before ever even getting it started!
It is a 73 tx650 with stock points setup. Am i missing something or could i have done something wrong when adjusting the valves? They were just too tight so i backed them out to the manual specs.
Any help or suggestions are greatly appreciated!
