ANLAF
XS650 Guru
I fried my battery! Ouch!
I used a car battery charger a few times when I was sorting out the charging system. Well, I put the battery charger back on today to give it a boost - it buzzed as they do but the dial did not move. I thought the charger had bit the dust. Tried it on the car, worked fine. Did some investigation and for those that don't know: Do not use a car battery charger on your bike battery - thar car charger trickles at 2-4 amps, which is way too much for a bike battery, which should trickle charge at 500 to 650 milli-amps.
Tomorrow I will pick up a new battery and a motorcycle trickle-charger.
I hope this helps - it will help my friend (it's his car battery charger), he is on his fifth battery, and thinks it is the bike at fault. He has been charging with his car battery charger and frying them, one after the other.
Anlaf
Anlaf
