truenorthmetal
I just installed the Complete Pamco Electronic Ignition Kit, #14-0902...and I have a few questions if any one could help that would be great.
1 - I received 3 pins - one went in the cam on the right side to locate the advance unit. The other 2 sounded like they were destined for each end of the advance rod....but there were pins already in the advance rod.....so out of the 3 pins I received....I only used 1.
Does that sound right or did I miss a secret pin install...?
2 - I was reading Hughs install guide as well as Pete's.....Hugh's showed a rotor with 2 magnets, and he said with left cylinder at TDC....magnets would align horizontally.
My rotor has 4 magnets....and they did not align horizontally....? Looking further, I now know there are 90 deg rotors and 60 degree rotors....mine appears to be a 60.
Do I need a 60 or a 90, and do my magnets need to align horizontally while I am at TCD...?
Below is the PMA while left cyl is at TDC - yes I am positive !
Next pic is advance unit while at TDC
and rotor assembly while at TDC
