XS1 frame rear size
Sarilhos
Europe
Hi;
I've recently bought an 1971 XS1B, but the rear has been cut to fit another type of seat;
I would like to rebuilt it to factory look, can some one help me getting some sizes for the rear part of the frame;
Note: if someone has cut it from a bike and would like to sell it, i would be interested;
IMG_20160221_100913208_zps3qyxjujv.jpg~original
FRAME-BACK_zps6tyuihos.jpg~original
I Believe the diameter is 19mm (0.74 inch) , is this correct
A: from top inside to the point where it start's to curve
B: From the curve to the welding point
C: on the curving point the distance from one side to the other (from inside the frame)
D: Distance between the two welding point (i think i have this one ;) )
E: The distance from the top (bottom of the tube) to an "imaginary line" along the frame
F: the length between the most outer part of the tube to the welding point
G: if possible the angle of the curve
Thanks
Hi, Sarilhos. My fender is in the way, but here's some pictures that may help.
Yes, the tube outside diameter is 19mm (0.75").
Note that the tail loop becomes narrower than the frame.
G: The angle is 40° from level.
Hi 2M;
Thanks for those pics, and special that angle value that is going to be off great use;
If ever had the change to take the other measures, let me know;
Thanks
Sarilhos
