pinstripe_chuck
If I leave it off will it cause engine problems?
Ive run mine for awhile without one and have had no problems!! But like hooktool says Im sure it will cut down on vibration, but not sure about breaking anything without it as the motor is already locked down in four places! Just my opinion!!
XsC
You can't argue with the guy that's doing it, and plenty have. The way to tell would be to ride one way, then the other and see if you can feel the difference. I would worry about it long term in any case.
I'm leaving for Portland in the morning-gonna be there a day or two, up to Vancouver and Anacortes, and then a week there in Portland. Any shops I ought to see? I bought and RZ350 out there a few years ago and picked it up, but the shop was not all that interesting.
John
puts more flex into the cylinder/head mounting studs increasing possibility of oil leaks
The "no top motor mount" debate has been going on forever.. And this may be a bit off topic but I have seen this type of discussion turn into a real shit storm.
Things to consider is that most bikes you see without the top mount are custom built frames and not hardtailed or modded stock one.
A custom frame is,if done correctly built from a thicker wall tubing then they used from the factory.
Ever wonder why there is a shit ton of bracing and gussets on a stock frame? its because even yamaha knew that the tubing needed it.
And yes guys that aren't running one and have custom frames do ride their bikes..
I put about 15k or more on mine last year..
