ljevans
I've recently purchased a 1977 xs650 from a friend with 35,000km's on it. So far I've pulled the carbs apart and cleaned them as well as I can (torch tip cleaners throgh the jets, checked the diaphrams, cleaned out float bowls etc), sorted out the charging system (new battery, new plugs, new regulator, new rectifier, new alternator rotor) as well as some issues with lights and i've gotten to the point where i was ready to take her for a run around the block. It starts fine and idles pretty well with the choke off (a little black smoke puffs when cold) and it seems to run decent through the gears (no stumbling etc) but when i get off the throttle i can feel the bike still pulling. I pull the clutch in and the rev's stay around 4000rpm. I can snap the throttle several times but nothing seems to bring the revs back down. eventually (maybe 15 seconds or more) it'll eventually settle back into a decent idle. They are (from what I can tell) the stock BS38 carbs. My friend owned it for about 8 years before I bought it and he rode it seasonally until about the last year that he had it when he bought another bike so i don't think that there's necessairly an issue with the jets as he rode in the same climate as I am all those years with no issues. The throttle linkage and cable are definately not hanging up as i can see the linkage sitting against the idle stop screw while all of this high revving is going on. I've tried spraying ether around the intake and that didn't cause the rev's to climb from idle so i suspect there's no intake leak? I also drained all of the fuel out of the fuel tank and the carbs at the same time that I went through the carbs (within the last 2 weeks) It also has the stock airboxes on it with decently clean air filters in them. I have yet to go through the cam chain tension, valve lash, timing proceedure so that's probably going to be my next stop unless anyone can shed some light on this for me?
thanks
edit - the exhaust has been chopped off at the muffler area. that's the only mod that I can think of but my friend did that right when he bought it 8 years ago and it always ran good for him so I don't think that's necessairly part of my issue.
thanks
