Hi,
I had made note of 5twins post, and saved the picture. Good to know it's a tried and recommended solution; however, and recalling all I intended to do at the outset was replace the spark plugs, I first took Marty's NAPA suggestion.
I ordered six plugs, the max NAPA online would allow with store pickup. After a week I called the store. They had gathered five plugs, but they would would have to get the sixth plug from Sacramento, and it would be a BPR7ES. I cancelled that one and picked up my five beautiful new NGK BP7ES plugs. Two are in yellow boxes with BP7ES, and USA, but no #1034 printed on them. Three are in the (I think newer) grey boxes which do say #1034. To me, the yellow boxed plugs appear to be higher quality. Nonetheless perfect condition all, not even a scratch on the boxes. I also got a spark plug socket thread chaser with some of the money I saved from no E-bay.
In the meantime, while waiting for NAPA, I picked up my previously ordered, from O'Reilly, the only Champion N7Y plugs I could find locally. You know, the other spark plug recommended in the Yamaha manual, that I've not seen mentioned by anyone here. Actually, they're Champion N7YC (superseded). "The C means they're made of copper," I was told. What were the plain old N7Y made of? I inquired. "Who knows." Was the answer. When buying parts, "These should work" are words that make me cringe. Anyway, the Champions look like they've been kicking around for a long time. Worn, crumpled boxes that can barely stay closed. No little plastic (or even the cheap cardboard such as NGK uses now) cylindrical things protecting the threads and electrodes. And missing the adapters that screw on the terminal studs. Such as they are, now I have two of those too. Probably a lifetime supply of plugs (my lifetime, if not the bike's). As well as the four Partszilla BPR7ES #5534 plugs I can transition to with the LZFH non-resistor caps as you suggest. Speaking of those; and note I'm still running with the original coils, and I believe, OEM wires. Did the XS650 originally come with non-resistor caps? If so then, should I replace the existing NGK LB05F 5KΩ caps with NGK LZFH caps regardless of which plugs?
Thanks for your attention,
R.
