shawnkva
Great clean work Shawnkva!
Thank you! I try to keep everything as clean as possible. I should invest in the shop towel industry.
I sure hope so. I'm going all in on this restoration.If that bad girl runs as good as she looks you'll be a happy camper.
You’re doing nice work. I’m enjoying following along. For keeping parts in order, I found inexpensive food storage containers from Walmart or anywhere really, worked exceptionally well for staying organized.
Oh and zip lock storage bags, sandwich size, and gallon sized.
Mike's has the reg/rec one, both sides plus lugs. I bought it and it was good. I think he carries the other one too. Careful to not shorten the wires there any more than necessary, barely long enough as is.
I figured out how the release the spades from connectors, so i should be able to just push them into new connectors.
I'm sure you already did but make sure you have a sketch of which wire goes where! And if not trying to reuse the housings a gentle wack in the right place can help with the disassembly process!
