Hey Fellas,
I have been reading throughout this forum for about a month now and I haven't been able to find my issue listed. I have checked the carb guide and read through most threads. I am not very mechanically inclined so please break down your answers. I purchased a 74 xs650 with only 6,100 miles on it. Its a very clean bike. It was left sitting for almost a year with some gas in the tank which caused rusting. I have fixed the tank, replaced the oil, cleaned the points, and had an electric issues that wouldn't let the bike run. This too has been fixed. I have placed in-line fuel filters and cleaned the carbs 4 times (usually they seem perfectly clean but I still take them about and hit them with some carb cleaner). The bike will start with a kick or the electric starter and a little throttle. But sometimes when you shift into first it will die, not usually though. However after a minute of riding the bike won't maintain an idle and will die when coming to a stop unless you rev it. Also it lurches when going down the road if you give it more throttle it normally will stop. So it seems like it is starving for gas? Its at the point of playing with it I'm deciding on just getting a performance carb. Any insight will be great. Thanks again.
