BS38 float pins don't have a head, they're just a length of (small) bar. They aren't a real tight fit either, if they're clean. They practically fall out if you turn the carb on it's side. If they are all gummed up and stuck then cleaning and soaking with penetrating oil and/or carb cleaner will be required. I usually use a 1/16" pin punch to GENTLY tap the stuck ones out. If they don't move after a couple GENTLE taps, I go back to soaking and cleaning, sometimes even applying some heat.
If jets are totally varnished and plugged, I usually just replace them. It's only like a $4 part and one that has sat all varnished up for a long time can be eaten away inside by that varnish. Then it's bigger and richer than it's supposed to be. I've encountered this a couple times, especially with needle jets.
