'75 XS650B dash lights
scott s
XS650 Guru
Rock Hill, SC
The dash back lights on my '75 aren't working. If I'm reading the wiring diagram righht, it should be a blue wire and a black wire. I pulled the headlight and everything seems to be plugged in.
I guess I could have all the bulbs burnt out. Before I pull the gauges to check that, can someone confirm that it's the blue and black wires?
Also, if I'm going in there, can you recommend a good LED dash light? Whicj of these two would you prefer?
http://www.ebay.com/itm/311384316339?_trksid=p2055119.m1438.l2649&ssPageName=STRK:MEBIDX:IT
http://www.amazon.com/Zitrades-10pc...pebp=1435083655919&perid=12SR1CTY1VTM1YD4HQTJ
Okay, maybe all the dash lights ARE burned out! Pulled the speedo and checked one of the plugs and I'm getting voltage. Time to order some dash lights, I guess.
EDIT: Dug through my stash and found four good ones. Success! And zero out of pocket.
