what is this Tom ? it looks like someone has tied the the coil feed to the signal supply ? unless I'm reading this wrong. As 2M says you definitely need to print out an A3 copy of your wiring schematic and start going through your wiring
YepTom you are mixing up the battery charging system with the engine ignition system .
The PMA and regulator /rectifier have nothing to do with starting and running the engine. They could be removed from the bike and provided the battery is charged the engine will start and run fine off just the battery for a while.I once rode 50+ miles at night on the battery once using torches for lighting
Everything runs off the battery ............not the PMA Regulator rectifier.
What is the image of ? is it your bike or something you saw somewhere. What are you showing us View attachment 101410
what is this Tom ? it looks like someone has tied the the coil feed to the signal supply ? unless I'm reading this wrong. As 2M says you definitely need to print out an A3 copy of your wiring schematic and start going through your wiring View attachment 101411
Yep, i understand that, hence me saying that i assumed the bike could start and run even if the reg is wrong. The image i attached is of the wires coming directly from the stator.
1: Is this a PMA set up or non-standard non-PMA? I can't find any picks online of something similar.
2: What are the other two wires coming from the stator?
3: If PMA, i need a new regulator.
Yep
excellent video guide 2M .
So Tom follow the 3x white wires from your Alternator to the male spade connectors you showed in a previous picture.Make sure that they are disconnected. If you have connected them to the other 3x white female connectors... disconnect them.
When testing the Stator white wires as per the video make sure that you do not let the ends of the wires short out . I would tape the 3x white wires together about 1" from the ends and then splay the 3x spade connectors out away from each other.
Follow the video testing and let us know the results . Ask if anything isn't clear ok.
Don't worry which wire is A or B thats just when they are in the connector. Just name any of the 3x wires A , B & C or 1,2 & 3 as you wish and follow the sequence in the video
Based on the video, the test proved that the stator works (0.6 ohms from each wire) as does the current reg/rec (diode test). Separately, I started the bike (battery 12.4 V) and put the VOM across the battery when idling, the bike sat around 12.3-6 V and the headlight increased its brightness when the bike was revved. How much should the battery charge once connected to the bike and the bike is being revved?
Once the bike was running, the horn, starter motor and headlight low/high beam started to work.
Does this mean the bike is charging? Hmm...
fit one of these LED charge indicators and you can see at a glance what your charging situation is even whilst riding.
http://www.ebay.co.uk/itm/12v-LED-b...739106&hash=item2ee0b62b98:g:DMwAAOxyRhBSqKcI
I have to say Tom you do need to buy yourself a Manual.... all this stuff is in most manuals, there are even free manuals to download if you do a search.
Haynes is better than nothing (just ) but most recommend the Clymer manual.
There are also 2x other books I'd recommend
Chiltons Yamaha 650 Repair & Tune-up Guide &
Chiltons Motorcycle Troubleshooting Guide which mostly uses the Yamaha XS650 in the examples .
Why do I feel like i need to explain myself every time??
