HOKAY DOKAY. So tonight, it being the first non-sweltering, non-raining day in a few weeks, I set out to change the oil in my bike.
Long story short:
With that said, here's the rundown:
First, I put my new 27mm impact socket on the large 1/2" drive breaker I borrowed from my mother-in-law, then used a hydraulic car jack and a block of wood to hold it firmly in place. A few whacks with my maul was all it took for each plug. The stock crush washers were very, very crushed, but the new ones fit perfectly.
Got a few bits of the crud in the picture above out in the oil at this point, but the big bit had to wait until I pulled the sump plate. The old gasket was not stuck too firmly to the engine cases (good news) but came off of the sump plate in pieces (bad news). Any suggestions how to get the last bits off?
The sump filter is blown out, too, but so neatly that I didn't immediately realize it was blown out. There is a T-shaped split, vertical up to the top of the filter and then about 10mm left and right.
Given that I'm looking at more involved repairs, I oiled up the new gasket and reassembled everything gently; I'll be taking it all apart when I figure out whether I'm repairing or replacing that sump filter, so no point in tightening things up fully.
The engine didn't make any sort of racket running, but obviously that chain guide has given up some of its friction surface. I understand there are no more Yamaha units to be had, so I'm down to Mike's for the part. That, and a full gasket set, of course.
Incidentally, the computer-cut sump plate gasket I got from eBay is just a bit large, but not large enough that I think it won't seal. Scaling is something that's always tricky when computer cutting.
