501Spanky
Before I ask my question: I have read the threads on wiring schematics and have not seen the answer.
Here's the question: Can I run a normal ISO cube relay using the yellow wire from the alternator as the trigger? I just need to know what is coming from that yellow wire ;-)
Here's the reason I ask: It's illegal in Canada to have an on/off switch for a headlight so I want to run it like the original system but not use the original components. The original headlight relay is just too damned big and I have removed the reserve lighting unit.
My bike is wired similarly to the diagram below except I have a 40 amp relay between the battery connection and fuse panel (5 amp key switch). I want to replace the headlight switch with the cube relay.
The bike is kick only, from scratch wiring, Mikes mini speedo, LED signals, aftermarket headlight.
Thanks for your time!
