Denisesewa
I've spent the past 3 weeks putting my basketcase together and getting it running decent as well as mocking everything up the way I want it before teardown and paint.
1977 , vm 34's , headers with Harley mufflers and pod air filters.
I have had some issues with timing, from everything I've read here so far I believe its just a tired engine.
The points plate ( NOS) is just about maxed out to get timing right. ( chain is adjusted properly)
When the cam comes to its TDC the Crank is 5 degrees past its TDC ( I believe this is cam chain stretch rather than a tooth off right? )
Dry compression is 120 and wet 140, both jugs are within 1 psi of each other ( electric start , mikuni VM34 carbs full open)
even so it does run rather well, time for a topend rebuild ?
jetting is another thing entirely , I'm @ 5500 feet , the carbs were jetted @ 180 mains , 42,5 pilots, it ran but crappy, I dropped the needle to leanest position and drilled some mains to 155, it runs rich still but closer, the thing thats confusing is the air screws are 1/4 turn out to get it to come off idle decently , I would think with that rich of a pilot at this altitude the air screw would be several turns out ? is this a function of the needle and needle jet being so rich ( and dropped to its leanest position) its screwing up the pilot circuit? ( I failed to note the needle and jet sizes)
I ordered 145 mains and 35 and 25 pilots but thinking the motor is so tired it may not be worth working on jetting until the top end is rebuilt? ( suggestions for needle and needle jet ? )
Anyway, any insight as to whether my thinking is correct and I'm on the right track would be appreciated.
Thanks
Thanks
