Luv that rotor swap - very innovative! Strip the black paint off that caliper to really show it off - you'll be surprised how much it "lightens" the look!She lives. 50 miles tonight for the test ride. Allison's taking it to work tomorrow. Woot! few little nigglies, natch, Dropped the mains back to 135 left the pilots at 45 found the choke orifices both were plugged, again? Starts when my thumb gets NEAR the button now. May drop them back to 42.5 yet shes a bit rich down low But I'll work the idle mixture down first. Rebuilt the vacuum petcock with a new Yamaha "valve", works perfect. Tank was clean inside, just put in gas and went. Might be just a little snug on my clutch push rod, clutch slipped at 5K coming up the hill at full throttle when it was good and hot.
View attachment 102828 View attachment 102829
Nice to have the lift open again. Now for the next project?????
Gary quote:
" Funny how the factory seems to have had things tuned pretty well"
I find it completely normal that these bikes run really well, when using stock air box, stock jetting, stock exhaust, stock alternator, etc.
Compare that to all the threads on here, in which pod filters, after market exhausts, larger jets, and PMAs are installed, and the result is months and months of attempts to tune the engine, and some never succeed at getting a smooth running engine.
I think the Yamaha engineers knew a lot more about engine combustion air flow and tuning than the average biker on this site.
14.7 volts is a little too high. It will boil out the battery electrolyte over time. Yes, you could try a higher wattage head light to lower that voltage. 14.1 volts is where it should be in a perfect world.
Hey xj.......................I like a man that is a contrarian! Congrats on shunning the view point that the metal plug must be removed, and staying with the stock mixture screw setting.I still have the plugs in my pilot screw holes, which I'm pretty smug about. The factory spec charging voltage is 14.5 +/- 0.5v .
While I agree with you that an xs ran well from factory stock. Many people have successfully ran pods, rejetted carbs, changed up exhaust etc without months and months of troubles. You don't read about it because there aren't success story threads on here, just help needed threads. I'm only posting this for the passerby reader, it can be done with some research and know how.Gary quote:
... runs as well with no filters as it does with stock filters. So if pods are between the two in flow I doubt they'd be a problem...
Hey, I can admit when I'm wrong (at least when nothing's at stake). My info came from an old owner at an auto electric shop, and it's possible he was talking about my model of car specifically. He was adamant about 14.6. Anyway, when then spec says 14-15 volts, I'd be satisfied with the spec personally. As we already concluded, after all this it's surprising how well factory spec works. If I was tweaking a charging system to remove a couple tenths of a volt I'd think something might be wrong with me.I guess we'll have to agree to disagree. My Toyota Camry charges the battery at 14.1 volts
Not my job..... and it's not her style...That is a nice little emblem, but I'd say that the chrome could use a little AutoSol polish and elbow grease Gary.
PS this gauge is wired directly to the battery, not tied into a stock wiring, after the ignition switch, down to the fuse box, back to the headlight bucket, sharing voltage with other loads.....Hey, I can admit when I'm wrong (at least when nothing's at stake). My info came from an old owner at an auto electric shop, and it's possible he was talking about my model of car specifically. He was adamant about 14.6. Anyway, when then spec says 14-15 volts, I'd be satisfied with the spec personally. As we already concluded, after all this it's surprising how well factory spec works. If I was tweaking a charging system to remove a couple tenths of a volt I'd think something might be wrong with me.
