Jake650
Thanks Jim. I do not recall seeing anything like that in my parts stash but will take a closer look tomorrow. I suspect I’ll have to go with option B.
I just realized we're gonna need an AC relay since it's the alternator that trips it. The ones I've been using for projects are DC. My bad. I did look on Mouser Electronics though. Here's one that should fit the bill. 6VAC coil, 10A on the contacts, SPDT, compact and only 8 bucks. There's plenty there to choose from.I think I’ll take Jim up his offer to help me source one.
You could be right Greg. I've never measured at the yellow wire, but everything I've read say it's about 5-6 volts. Anyone care to measure theirs?Jim I think it's 12 volt AC coil needed. This is from a XS2.
I just measured mine. I believe you are correct. Charging 14 at battery I got 6ish at white wire going to relay. Now that I think about it that would be right because it's one leg of stator to ground. Would have 12 between the legs. The new year is not a total loss, I learned something today.Anyone care to measure theirs?
PCB= printed circuit board. Means it's soldered onto the board like a chip. You want the quick connect.You guys rock!!! In looking at the data sheets there seems to be two pin types: PCB and quick connect. Since the pic says reference only I'm not certain on which terminals it has. I'm definitely not the electronics type and have no idea what to use if it has PCB pins. Plan is to call them tomorrow and see which type it has. I'll let ya all know how it goes.
Yes you can. Here's a junk one missing the covers. I cut the wires away and a gentle tug and twist popped it out in my hand........did have another thought and that is: could the starter relay portion be separated from a stock unit? That would have to make it a good deal smaller.
