Set the motor on the TDC mark, then install the cam, and connect the chain on top of it. You'll need to "jump" the chain around on the crank sprocket as you rotate the motor to keep both ends up on top. String some wire through both ends of the chain so you can drop them down into the motor a little to provide slack for "jumping" the chain around the crank sprocket.
