NewestOnTheBlock
I've been working on my 1980 xs650 for awhile now. I think I have most of the issues worked out, except for one last thing. The bike is running lean. I pulled the plugs and they are black, and all the issues that are associated with a lean bike are present.
I went out and got a clymer manual. Its great, but I'm slightly confused.... In the book it describes in detail the dead cylinder method. It talks about adjusting the idle mixture screw and all. However later on in the book, it says "All 1980 and later models have no idle mixture adjustment method". So what I am interpreting that statement as....is that the dead cylinder method that is described early on in the book, does not apply to the 1980...Is that correct. If so, how would I go about addressing the lean carb?
Secondly. My idle mixture screws seem......well.....weird? When screwed in (down) all the way, one side seems fine (as in where it should be). While the other side screws in a significant amount more....almost double. Is this normal? or did the previous owner do something to it? Threading is fine, just it goes in almost twice as much as the other.
