just thinking out loud here.
if the po changed the floats might the needle valves be the wrong length as well ? I don't know if they were all the same length through the model /carb range or not ?
Very good idea. After tearing down the carb, I think I got a idea of how the previous owner was thinking. I could kind of see how he or she thought about things, you know, gain a generally feel. I wouldn't be surprised if the needle valves we're indeed different than stock. I have only taken the actual needle out, but taking both the needle and needle valve out might bring it down to the desired 22mm....
If you remove the needle valves altogether will the floats then sit down far enough that you could achieve a 22mm measurement ?
When adjusting the tang and float heights remeber not to put any undue pressure on the needle valves , the springs should be uncompressed not pressed down .
