alfredo
1978 xs650 Special
Some of you might know that I have spent some time rebuilding my motor, running my motor, rebuilding my motor, running my motor and rebuilding my motor over again. It's been a few years since I jumped on here knowing absolutely nothing (haven't come far from that btw) and really made an effort to dive in. I won't say much about the community that Travis built (xs650.com) because I know everyone here gets tremendous benefit from it. Wheter you just browse and never post, are an active asshat to everyone or an active contributor. You all get value here. No question.
What I do want to take a second and talk about is vibration. There are a lot of things that you can do to your xs that make it more reliable, sleek, sexy and fast. Most of these things are very well covered in other posts, but the one thing that I personally feel is understated is the RePhase. I have had the fortunate, and unfortunate, pleasure of experiencing the very same xs motor in various states and configurations. Now, if you are a professional racer or motor builder then I am sure this luxury is afforded to you all the time. I just don't think thats what makes up 80-90% of this community. I think there a lot of guys and gals like myself who are budget and time conscious and really want to get it right out of the gate. No time to test and test and just want to cruise.
When I first started riding the first rebuild (360°) it vibrated like a wild angry animal at speeds of 60+. If I tried to go up to 70+ the vibration was REALLY bad, sometimes I could barely keep my hands on the bars. I actually felt like it might shake loose, despite others saying it was normal. I was able, through the help of loads of forum members, to tune out some of this. The problem was it was still there. Lots of suggestions that would certainly do the trick to tone it down; squishier grips, bar snake, etc., but nothing that made a huge difference without a good amount of kit/add-ons. The vibration always felt wrong to me. I mean, I get the mechanics and why it does it, but it never really felt like something I could look forward to experiencing when riding the bike. And to me, I wanted to look forward to riding the bike. Enter the rephase. I read a ton about it and it seemed like the holy grail. So, I did the hard thing to do after spending all that time and cash on rebuilding the motor and tore it down again for the winter to do the rephase.
Saving the money and the time took awhile. I went all out this time. PMA, 5th overdrive, rephase crank/cam, but kept my bore from the original rebuild. No 750 kit in the budget and from all of what I could read the 750 just gets you to the max speed quicker. Doesn't really do too much for you unless you are racing or are really interested in getting to your cruising speed a little quicker. Neither of which are my interest or worth the $$$ to me personally.
To start to shorten this story up, I put the motor together twice with all the newly worked parts. First time I had the cam off one tooth and the base gasket was seeping. Once it was all together I ran it for about 50 miles, but even then I could tell the dramatic reduction in vibration. I never got it above 65, because of my past experience with the bike starting to vibrate like crazy before. Because the bike still vibrates a little more around that range, so naturally when it started to vibrate a little more I got scared and thought it was going to be as bad as the first rebuild.
Enter this past sunday. I was meeting up with some friends to take a ride to Nags Head (about 110 miles one way) to give the bike a proper shake down. This meant getting on the interstate which in my area means a posted speed limit of 70mph. Needless to say I clinched my butthole and went. The bike ran incredible the entire way. There is a spot where the vibration gets a hair more around 60mph (I am assuming its about 4.5k, but have no tach hooked up) but its an incredibly smooth vibration compared to the 360° phase. All went well barring some slight clutch cable adjustment needed. Even at speeds of 85-100 it barely vibrates more than a subtle hum. I have solid grips, solid mounted bars and also have all motor mounts hooked up and tightened down. I never maxed it out, but it certainly felt like it wanted to keep pulling even at 100mph. I was scared and impressed at the same time. My little xs was pulling away from a 70s ironhead and a 2000s harley 883. There were a few times when I just rolled on the throttle for a few minutes and got up to around 100+ and would look back and those guys were gone. They were right beside/behind me pulling and then they just vanished. None of us could really fathom that they couldn't keep up. Both of those bikes will get to 60+ faster than mine, but neither can keep up. I never maxed it out, but it always felt like it would go more and more and more.
So, long story short; While there is a lot that you can do to remove the vibration from the stock configuration, there is nothing you can bolt on that gives you as much of a dramatic improvement as doing a rephase does. Also, the 5th gear overdrive is an absolute MUST if you are doing a rephase. The benefit of the rephase, I feel, is dramatically understated on this forum. From my personal experience. I don't want to start an argument, just state what my experience has been.
Lots of thanks to Hugh and Pete for teaming up to offer such a great/painless upgrade available for this motor. If it's within your means to do this now or in the future. Do it. And give Hugh and Pete your money. Others may be able to do it, but these guys are certainly the top shelf.
