Fernando
First time post, long time lurker. I have a 79 special 2. When I got the bike i replaced the battery, put in a new alternator rotor, changed the regulator/rectifier with the radioshack homemade bridge rectifier and the chrysler regulator from napa auto parts.(THANKS FOR THE CHEAP FIXES GUYS!) This fixed the charging issue that was causing it to die regularly. Ever since it never has left me stranded.
Now I keep having acid drip down over the frame! I have reattached the battery vapor tube and even attached it with wire so it can fall off, but for some reason it still seams to be leaking and spilling on the frame.
The tube is plenty long and runs to the base of the frame, I keep checking the fluid and it never looks to be low, always between the max and min lines. I am not sure what is causing the leak. Could it possibly be the kickstand lean? If so it seems like a poor design to have for a motorcycle battery.
Im left scratching my head on this one, thanks for the help.
