I am to the point of my build to start the motor, set the timing, sync the carbs, and see if I need to grind anything off and relocate it. The motor has always seemed to turn over stiffer than I thought it should. And the kick starter wouldn't always want to engage until half way through the stroke. Maybe it's been just sitting for a while, I thought. Turn on the gas, click the choke, turn on the key, bring it up on compression and give it a kick. CHUFF and an immediate kickback that about broke my foot when it swung the kick back at my arch! Limped around the yard for 20 minutes cussing and trying to decide if at my advanced age the electric start should be put back on the bike. Well, that bike wasn't going to beat me this close to the end. Jumped up on the kick with a vengeance and OUCH! Come back out to the bike a while later and start checking the setting for the Pamco that came on the engine when I got it, Check the valves again to see if they rock from intake to exhaust at TDC. Finally decide to open the clutch side up. Find out the kick start problem is the "onion shaped" spring clip is not in the relief in the case, but floating around not letting the gear disengage from the engine. I'm feeling pretty satisfied as I'm trying to remember how I took all the springs and washers off the shaft when I happen to look over and see the filings and chewed up look of my tach drive gear. Closer inspection shows that the oil pump gear that drives the tach is way crooked. Someone has been turning this motor over without the little case insert to hold the tach drive shaft down and engaged. Looks like I will be replacing an oil pump shaft and gear at the very least. At least I wasn't out on the highway and lost an oil pump. I'm starting to wonder about this budget motor I bought to avoid a full-on rebuild to the motor I got the bike with.
