Lluber
Noob
Also, here is what My brushes are looking like.
Remove the right brush. Set your VOM to the lowset scale ohm.
Stick one probe in the brush holder hole to contact the inner ring.
Put the other probe on the outter ring.
You should get a reading other than "I".
If you don't chances are the probes aren't making contact.
That reading is trash.
Remove the stator(it's two screws) so you can get your probes a good purchase.
A good reading should be 5-6 ohms. Lower than 5 you are working on borrowed time.
sidebar I've never seen brushes wear that evenly.
Do they wiggle side to side in the holder? You can check from the inside of the stator while it is off.
Hey,So, my 83 650 seems to be having some battery issues or recharging issues or something along those lines. Bought the bike in march PO told me he had put in a new battery as well as new tires.
The problem: Bike starts and runs (I typically kick start it because my electric start only seems to work when the bike has been warmed up Maybe that bit will help with what the bigger problem is here). So I took her for a ride.. got about 1-2 miles from my shop and the bike shut off. I put it in neutral, kick it....nothing. Green neutral light is on but a little dim, headlight is on but also kinda dim. Push it until im nice and sweaty and I'll press the start button (starter is clicking but bike wont start) kick it and it starts up, let it idle for a min.. I put it in first, move about 100 feet and it dies. I gave up on bothering trying to ride her back, I pushed it to my shop, kicked it, it started. She idled for a few min and sounded ok literally as soon as I tapped the brake lever bike shut off. I also noticed while It was idling in my garage the headlight seemed to fade then come back as I would rev the throttle.
This happened about 2 weeks ago and I put her on my tender charger and that seemed to fix it. Since then I've only taken her out once (20 mile ride) which taught me how to change a tire as well as what running out of gas on the highway is like
I'm sure this has been discussed but I wasn't able to find it. Seems like I need to check the water levels in my battery (I'll do that tonight) and add distilled water if its low. IF thats not the problem what do I begin checking testing next?
Thanks.
