section8joe
I have no bullet connectors. Everything is soldered. There is a small ground going from the actual negative side of the headlight to a rivet on the headlight bucket. My original ground was attached to the screw on the headlight ring. Apparently this ground was no good. Can this resistance be causing my charging strain? I'm going to drill a larger hole into the headlight bucket and run a ground straight to the negative terminal on the light tomorrow.
