gotcha
it is just a cable link across the relay switch with a piece of wire so that the lights are constantly on .
The only problem with this arrangement is when your battery is a little flat.... the lights will sap your battery when using the starter motor which is why yamaha put the relay in
You could put a remote light isolating switch in the wire link if it becomes a problem
sounds great Kev , great tickover good throttle response. you must be well chuffed.
2 into 1 certainly sounds a lot different ..i wonder whayt effect it has on power through the range.
Is that with the original BS38 carbs ?
