denaamisarjan
Hi everyone,
I've been reading the topics for a couple of months now, but hadn't anything to write so far. So here's my introduction.
I'm Arjan, from Holland. I got a XS650 custom with a velorex sidecar.
I bought 1,5 year ago, rather cheap. So before driving it, I had to repair some stuff.
What I did so far:
changing the tires,
mounting a modern alternator and regulator
repairing electrical stuff (indicator, break lights etc.
changing the slides inside the carbs.
adjusting the valves
what I have to do: fix the Bendix, the starter motor won't kick in.
check the carb. alignment, since the bike is vibrating between 3000 and 4000rpm.
For now, the bike is running great. There's just this one issue, that keeps on following me:
the crankcase vent. is blowing enormous amounts of oil. everything behind the opening is covered in oil, lots of oil!
To solve this, I made a hose, leading from the vent. to the intake-filters. Didn't help, there's still lot's of oil on the bike. I think it's blown away by driving-wind, before it is sucked into the engine.
Today I drove about 150km, mostly highway. I must have lost about 0,3 liters via the ventilation.
I'm afraid, i'll have to pull the heads. But am not sure what the problem might be. Since the bike is running great en has plenty of power, i'm not sure if for example the piston-rings are worn..
what do you suggest I do?
What I did so far:
changing the tires,
