Pyrobooster
Hey boys,
I have been having a hard time chasing this problem down.
My problem:
After about 12 - 15 mins of normal riding, my bike begins to bog and cough a bit like when you are running out of gas. After another minute it gets worse, I have to give throttle at stop to keep from sputtering. Maybe another minute or two later it will sputter and cough and bog even when running at 30mph with throttle. Then if I stop or slow down it typically dies. Lights work still so the battery isn't dead I think. Then after sitting for 15 - 20 minutes I can usually restart and run for 10 mins before having the same problem. It an intermitent problem, it happens most of the time, but not every time.
I usualy keep a battery tender installed when parking overnight at home. The battery is 4 years old.
I have heard these following possible problems on other forum threads:
-Bad coil, fails when hot
-Clogged something in the carb
-Floats misadjusted in carb
-Ignition problem
-Weak charging system
Can someone please help me understand where to start?
Thanks in advance,
pyro
My problem:
-Ignition problem
Thanks in advance,
pyro
