I decided to replace my stock TCI. I had contemplated rebuilding the stock unit but discovered mine did not have any settings other than Idle and Full Advance. Perhaps that part of the circuitry is faulty but the IC controlling that is not available (18 Pin custom 4 quad comparator). The later TCI units with the double sided PCB have an HA17902 14 Pin quad that can be replaced with an LM2902N and the Darlington transistor with an ST901T.
I settled for the Boyer Micro Power XS 650 Kit00303 due to it being a local UK product with good customer feedback and good technical assistance.
Before removing the stock ignition I hooked up a strobe light to confirm where the Full Advance position is on the alternator/timing plate. With the XS SH no marking is provided for full advance because this is controlled by the TCI unit and it is assumed that once factory set it should never need to be adjusted again.
In the photo above, as pointed out by others, the full advance coincides with the center of the drain groove in the side cover and this I also observed. I also calculated the position using trigonometry for 40 degrees from TDC and have filed a full advance mark on the alternator very carefully based on these calculations.
I also confirmed that the TDC marking was correct and checked the camshaft on the RH side to ensure that the pin hole was in the correct location for TDC. The TDC marking on the steel plate is to the right of the "T".
With the crank set at TDC a 3mm dill fits very firmly in the pin hole and shows vertical with the engine.
KIT00303 as supplied assumes that the XS is fitted with the advance and points mechanism. Although this is all removed during the installation, the Kit requires that the bushes remain in place. The mounting of the magnetic timing rotor uses these bushes as spacers to center the mechanism.
Magnetic rotor: The threaded section is approximately 12mm OD and pushes into the LH camshaft bush.
The threaded rod is secured on the RH side of the camshaft and again the fitting is approximately 12 mm and fits into the RH bush.
The XS SH came with TCI ignition so no bushes were ever fitted to the camshaft. I made up some spacers on the lathe from Aluminium to allow me to center the magnetic rotor: Approximate dimensions 12mm ID, 16mm OD and 10mm in length). Alternatively I could have bought a set of bushes.
The lip on the spacer to the left was added to give a better seating on the RH side of the cam. Both spacers were fitted and then the magnetic timing rotor secured to the camshaft as per the Boyer instructions.
The next step involved replacing the old coil with the new coil supplied with KIT00303. I decided to mount the new coil in the same location as the old and this required fabrication of a mounting plate to bridge the old coil locating bolt holes. I used 2mm Mild Steel with a triangular section removed to accommodate the new coil.
The following photo shows the new ignition coil bolted in place and is viewed from the LH side of the bike.
I connected the new coil to the harness using a short homemade two lead extension fitted with male spades at one end and female spades at the coil end. The red/white harness wire (power from ignition switch) was connected to the positive side of the coil and the orange harness wire connected to the negative side of the coil.
The male spades were inserted directly into the plastic connector and these two wires will be picked up from the harness to connect with the ignition box using the harness connector for the stock TCI located on the LH side of the bike next to the rectifier/regulator connector. These two harness wires serve the exact same function for the Boyer ignition as they did for the stock TCI. Red/White provides the power from the ignition switch and the orange controls the switching of the coil via the ignition electronics.
Note the red/white and orange wires on the left of the connector coming from the harness and the red and black wires exiting the plastic connector and leading to the coil:
It is possible to fit the Boyer ignition box comfortably underneath the indicator and auto cancel units by strapping it on with the supplied plastic ties. Although I initially placed the Boyer ignition box in the original stock TCI plastic case, Boyer Bransden advise me that the ignition box should have free circulation of air around it to prevent overheating. I fabricated a simple holder for the ignition unit with holes positioned for locating the plastic ties and to allow the unit to be bolted back in place using the original TCI mounting bolts.
A length of heat shrink was placed over all 5 wires to stiffen them up a little so they could be more easily secured to the chassis during installation.
The Boyer pickup coil plate was then fitted over the magnetic rotor as per the instruction sheet i.e. the crankshaft was set at Full Advance. I found this easier to do with the plugs in rather than out. I lined up the paint spots on the Boyer timing rotor with the hole in the pickup coil PCB then tightened the locking nut on the RH side of the camshaft.
Note: Originally the wires (Black/yellow and Black/white) from the pickup coil PCB were run back up towards the coil following the arc of the ignition leads. I made an extension lead to run these pickup wires under the ignition coil and then traced the RH side of the harness back over the top of the RH air filter and down behind the plastic tool compartment into the location of the ignition box/rectifier.
Change: Following feedback from TwoManyXS1Bs regarding possible interference from the ignition coil/leads being picked up by the Boyer black/yellow and black/white timing leads I have rerouted them directly up to the frame above the carburetors where they are strapped to the harness. From here they follow the RH side of the harness back over the top of the RH air filter and down behind the plastic tool compartment and into the location of the ignition box/rectifier.
In the photo below you will notice that I have tried to keep the wires from the pickup coils away from the ignition leads. Where they do cross each other under the tank they are almost perpendicular. This configuration virtually eliminates any coupling between the wires.
The pickup wires were then fitted to their corresponding wires from the ignition box. The remaining 3 wires from the ignition box were then grafted directly into the original TDI box connector on the LH side of the bike next to the rectifier/regulator connector using spades (Note: It was necessary to extend these three wires from the ignition box to get a comfortable fit). The red wire fitted to the red/white ignition switch power lead from the harness, the black lead connected to the orange lead in the harness which traces back to the negative connector on the ignition coil, and the white earth cable from the ignition box connected with the earth lead in the harness.
All wiring terminating with the Boyer ignition box in the cavity space behind the rectifier/regulator and above the swing arm bushes will be hidden when the triangular shaped plastic tool compartment is back in place.
The connection of the red, black and white wires with the Boyer ignition box was made to the original TCI connector on the LH side of the bike using male spades.
All wiring was wrapped in PVC tape and secured firmly to the bike frame and harness to ensure they do not get bounced around too much. The original spark plug leads had protective tubing over them, possibly made of rubber. I removed these, cleaned them up and placed them back over the new leads for added security.
The Timing Adjustment is explained in Entry 4 Below.
