NorazDad
NorazDad
Thanks for helping me on this hunt. Yep Griz, I took the switch off yesterday and re soldered the the brown(it looked pinched) and the red white. But I didn't check voltage. The crazy thing is that the hiccup occurs at exactly the same point in warm up and run. I was able to set the idle and set the timing for five or so minutes and then took it for a test ride. The bike ran strong for about a half mile and then break started and then quit. What would it be that it happens at the exact same point in the run? I'm going to dig into the Reg/Rec today and look into a Mosfet.
I need to check AC out of the PMA, etc. I am going to try running battery only and see if there is some conflict coming from the charging system...but it is charging, maybe it is spiking somehow when it gets hot and setting the whole thing off. I hate to take the PMA out, but I may have to to check the windings and the routing of the wiring. It's crazy because this came up all of a sudden.
Thanks for your input and 2Many, fuel does not seem to be a problem, but I will check again. I did a flow test from the tank and through the carb bowls and fuel flowed fine. I've also had the carbs off and on and cleaned them numerous times as my previous posts indicate.
What would interrupt ignition at the same point in a run?
