Found the below metal chunk stuck to the rear drain plug magnet of a friend's 1980 XS650. Can anyone I.D. it? Bike seems to run and operate fine. Chunk is a little less than an inch long.
Good point. I used Permatex Motoseal 1. Doesn't have the problems ppl say Yamahondabond has. I think it is the same stuff but thinned. I let it dry overnight personally, but a thin layer would probably be pretty dry in a couple of hours.ck the sealant for cure time prior to hit'n the road.
I didn't think you could replace the tranny (or just the bad gear) without splitting the cases. Am I wrong?8:00a - 10:30a: get engine out of bike and lay it upside down in living room
10:30a - 12:00p: start removing bottom cover
12:00p - 1:00p: lunch
1:00p: - 2:00p: finish removing bottom cover
2:00p - 2:30p: plop in new transmission
2:30p - 3:00p: reinstall bottom cover
3:00p - 4:30p: reconnect engine to bike
4:30p - 5:00p: test ride
I'm sure you could, using ship in a bottle techniques. Bottom case I was calling bottom cover. Would be a good opportunity to fix the neutral light too, if it's a bad sender.I didn't think you could replace the tranny (or just the bad gear) without splitting the cases.
Concurring with whom?Any concurring opinions on replacing transmission by only removing the right-side crankcase cover?
Hey Dogbunny! Say HI to Mr. Stupid. I don't know how many years ago I drained a 5th gear dog out with my oil. It looked just like yours. One of my buddies gave me a transmission. I bet it's been over 10 years. Maybe 15! I even took a week long trip on it. Still going. One of these days, I'll get around to replacing the transmission.Thanks for all of the responses, and thanks to aldo5468 for the excellent link.
How stupid do you think it would be to just continue using this engine? As Downeaster implied, when the next dog goes it could trash the whole transmission, but on the other hand, I have plenty of spare transmissions, and the labor replacing one gear should be about the same as replacing the whole tranny?
