Rez Fink
The following link is NOT my video but my cam chain is doing the same thing. Is that movement of the plunger/bobber normal? If not, suggestions?
Thanks in advance.
Thanks in advance.
Yes, 6 bolts and out it comes as an assembly. If your chain is really badly stretched (hopefully not), I suppose there'd be a (remote?) possibility of it jumping a tooth on the cam or crank sprockets. Therefor I wouldn't turn the crank while you have it outis it a simple matter to remove the adjuster, rod, spring and damper/washer assembly?
Yeah.... my bad. What was I thinkin'.No need to remove the housing.
Well, this is what was in there:
5twins, you are fully vindicated - no washer/damper.
I will measure up and see if I can determine what is missing. Then, see if I can source the missing part(s).
The only part you are missing is the damper, which is readily available from Partzilla, and is cheap, except you have to pay for shipping.see if I can source the missing part(s).
Here's a write-up on the type D and E tensioners (posts 22 and 23), also the size and an eBay source for the copper damper washers .....
http://www.xs650.com/threads/cam-chain-tensioners.1056/page-2
You haven't run the bike yet but if you had, you probably would have noticed a ticking like a loose valve even with the valves properly adjusted because of that missing damper washer. Start watching eBay for a type E tensioner assembly. They can usually be found for $20 or less if you're patient. You rarely run across the individual parts for sale like the plunger or lock nut, just complete assemblies, but like I said, they're not that expensive. If you plan on keeping the bike, I consider this a "must do" upgrade.
