You can't buy the copper damper washer from Yamaha anymore, they've discontinued it. They only sell the later, thicker rubber/metal damper washer now and it's ridiculously expensive (about $11). Besides, as I mentioned, it doesn't fit up right on the older Type D and early type E assemblies with the 60mm long adjusting bolts. If you need a damper washer for your type D or E adjuster, measure the length of the adjuster bolt. That will tell you the thickness of the damper washer you require. The early 60mm long adjuster bolts use the 2mm thick copper washer. The late 59mm long bolts are made for use with the "new" 3mm thick rubber/metal washer.
