Cam Chain tensioner pivot arm what are torque specs??????
jonbo30
chicago IL
I cant find what you should torque the 4 screws that hold the cam chain tensioner pivot arm in place?? thanks jb
in the engine 7 ft lb (6mm torque) be aware the back bolts are longer (14mm), fronts are a special shouldered screw, use blue loc-tite on all of them
its 79 xs 650 sf. there 2 shorter bolts and 2 longer bolts as long as they dont exceed 14 mm 7ft will work? thanks
Are you guys talking about this?
Anybody using any other type of screw for this when their bolt head stripped?
An M6 allen bolt would be perfect but just seeing what others have done.
I know there is a special shoulder but was curious.
Posted via Mobile
