1. Dismiss Notice
    Dismiss Notice
cam chain tensioners
Discussion in 'The Garage' started by inxs, Mar 26, 2010.
  1. The pikey 84
    The pikey 84 Xs650 operator
    The engine was rebuit by someone else and the long front tensioner was not in it...I'm new to working on motorcycle engines so I'm going by the book..and it shows to have all 3 timing chain blocks in the engine. 3rd pic..just freaking out..
  2. TwoManyXS1Bs
    Yeah, 3rd pic is the perpetually shown backwards install.
    Look at post #36, just before your first post.
    That lower slipper goes to the rear of the case.
    Edit: Still looks goofy, but here's a revised pic.
  3. The pikey 84
    Pictures he posted that is the correct mounting of the tensioner?
  4. The pikey 84
    So it's supposed to be in just like that but with the rubber facing towards the back of the engine?
  5. TwoManyXS1Bs
    No, the rubber faces forward. It arrests the chain "fling-off" from the rear of the bottom sprocket...
    The pikey 84 likes this.
  6. The pikey 84
    Oh ok thank you !
    TwoManyXS1Bs likes this.
  7. TwoManyXS1Bs
    Be mindful of the 4 screws that bolt that thing down. 2 should be fully threaded, 2 should have a slight shoulder. The 4 holes in that tensioner block should have 2 that are slightly larger, for those 2 shouldered screws. The 4 mount holes in the case should have 2 with a slight counterbore recess, for those 2 shoulder screws. See if you can see those...
    gggGary likes this.
  8. The pikey 84
    So that is the correct way to install it?
  9. The pikey 84
    Ok.gotcha! Thanks for everything!
  10. TwoManyXS1Bs
    Should be. See if the shoulder screw alignment agrees with his mounting...
  11. The pikey 84
    Ok. I'll have to get back to you on that..
  12. JWASH
    JWASH XS650 Member
    Help! I'm doing a top end overhaul on a 1980 XS650 that fell in to my lap. The pistons had seized in the bores, so it needed some love and attention. I figured that I should probably replace the Cam Chain tensioner while I have the engine apart. Trouble is that I've read on this forum that the MikeXS stuff is not good and I should stay away from their stuff. I assume I just need the front "Guide Stopper 1" as the parts books refer to it as. My problem is that MikeXS is the only place I can actually find one for less than $100. Does anyone know of an alternative supplier - or can you tell me wether then one I have is worn or not. It does have a 'U' shapped profile, but i'm not sure if that is to keep the chain tracked correctly.
  13. Superjet
    Superjet XS650 Guru Top Contributor
    TwoManyXS1Bs, JWASH and Jim like this.
  14. JWASH
    JWASH XS650 Member
  15. JWASH
    JWASH XS650 Member
    Thanks Superjet! I've PM'd gggGary to see if he has any left . . .
  16. Superjet
    If you need a tensioner, I do believe that I have one available. I will need to confirm if I still have in the heap! JC
Share This Page
