cam chain tensioners
I’m getting ready to install the type E on my ‘76. I have everything I need except the highlighted gasket. Parts list shows I need 2? IMG_2813.jpegunless I’m seeing it wrong, why would I need two? Also can I just make my own gasket or is it more like a fiber washer?
It's actually a copper sealing washer, and I'm not sure why the parts diagram calls for 2 (a mistake probably?) because you only need one.
Thanks for that clarification 5T but what size is it? Can I use an O-ring?
The only measurement I know off hand is that it's about 1mm thick. The O.D. and I.D. shouldn't be hard to figure out though. Looking at Jim's pic, you can see the O.D. is about the same as the round portion of the lock nut. The I.D. will be slightly larger than the screw diameter.
