connor1
The tech section references an online how to "http://www.iwt.com.au/mikunicarb.htm" as a good guide to understand how to tune the Mikuni carbs. I have a 72 XS aafter warm up, my midrange performance sucks. The engine seems to stumble all over itself. I am thinking about pulling the carbs, taking them apart and cleaning and adjusting them. However, I cannot make out what the author is talking about in the sentances below in regard to jetting under fig 7.
"While jetting carburetors, place a piece of tape on the throttle housing. Place another piece of tape on the throttle grip and draw a line (while the throttle is at idle) straight across from one piece of tape to the other. When these two lines are lined up, the engine will be idling. Now open the throttle to full throttle and draw another line directly across from it on the throttle housing. At this point, there should be two lines on the throttle housing, and one on the throttle grip."
If I draw a line from the grip to the throttle housing it will not be straight as it will have to go down my handlebars, across the gas tank, on to the head and finally to the carb where I believe the throttle, and therefore the throttle housing is located.
Maybe I dont understand what the throttle housing is? Is the author referring to the switch housing that is mounted on the handlebars adjacent to the throttle grip? Is this where the second piece of tape goes for reference later?
