lonzo22
I was stuck trying to get a 004H CDR CARDINAL RED for a 1980 xs650.
I finally decided to match it close as possible . Went to AutoZone took the side cover found dupli color BFM0317 Electric Currant Red Met (EG) Or DSFM317. It is actually a Ford Motor Co paint so if you are stuck like I was it is a viable solution
I realize Yamaha wants to hold on to there secrets but, 30 years is long enough. Who ever has the key code for the paint is holding on to some valuable merchandise. Bless their heart.
A can was enough to do the gas tank. But, not so fast, you will need a bottle of alcohol, or can paint prep about 10 bucks a can of primer I used gray, about 8 bucks, the can of BFM0317, 8 bucks and clear coat to top it with about 8 bucks. So for about 30 bucks you can get a very close color and improve the looks.
