Hey all - so I replaced my push rod seal and finally fixed a lingering oil leak. No more drips or cardboard under the bike.
But, a little while after replacing the seal, the electrical system stopped charging. When replacing the seal, I de-burred the opening, creating metal shavings. I tried to be neat, but could it be possible that some shavings got stuck to the alternator and FUBARed my charging system?
Good battery holds a charge for weeks. About 2 years ago I did a complete test of the charging system from A-Z using the charging guide and a lot of help fro you all. At the time it turned out the reg/rec was burnt out, so I replaced it with new from MikesXS. The system was working flawlessly until now.
Now the electrical system will not charge or maintain voltage (13v) with headlight on while riding/revving. I made it to to the Slap Test, and nothing - no magnetic field is being generated.
So anyone else experience the issue of a failing charging system after push rod replacement / deburring?
Thanks for any feedback you can provide
