My TX came with a bunch of spare parts, rubbish mostly. Included was a beaten up clutch activation lever which I think was of an earlier model or some other bike. The distance between the pushrod hole and nipple hole was only 30mm, whereas the one on the bike was 35mm, so not much use to me, so I took it apart.
The screw part was a bit bashed around on both the screw and the dustcover. After taking it apart, I cleaned up the screw part, turned the other end down a bit, fashioned a lever and welded it to the screw. For the dust cap I turned up one with a lip to retain the rubber seal. Not sure if the seal is of any use though, as soon as the clutch lever is pulled, the seal clears the female screw housing anyway.
Anyway, that done I drilled a hole for the clevis nipple housing and turned up a new pin. I drilled the nipple clevis pin hole 10mm further away from the screw than the original actuator. Clutch action is a lot lighter and you can actually feel the plates separating.
