Hi all
Just having issues with my 78 the clutch to be more precise.
Recently my clutch has not been disengaging so as soon as i gear select from neutral it stalls.
Took clutch casing off and found that the main nut holding basket on was loose as hell. Would this account for my stalling? I have also noticed that I only have the main nut and a washer that due to its kind of concave appearance i take it as the spring washer, is there one missing? i have checked most of the threads but can't track down a definitive answer, I am assuming from looking at different schematics i am missing a plain washer size (thickness) unknown.
With the spring washer do you install it with the concave side facing in so as the nut with have a pressure applied to it as to stop loosening?
thanks in advance
thanks in advance
