I know that title sounds vague, but that is exactly what it did. Just finished up this rephase build. Upon the first try to disengage (pull clutch lever in) the clutch while the motor is running, I noticed a "shutter" as soon as I dropped it in first. Kept the clutch disengaged and revved it a few times, and it seemed to go away. So I sat, and let it warm up a bit more while in first, then feathered the clutch and let it pull me out to the street (about 60 feet or so away). Once on the street I attempted to release the clutch lever completely as one would normally do (nice and easy)....and as I let it out, it began to pull, but then just kind of shuttered once the lever was all the way out. It did not lock anything up as the motor kept running. I immediately grabbed the clutch and listened...didn't hear anything obvious, tired again, same thing, it just felt like something was binding up.
So. shut it off and back inside...
-The entire clutch assembly came out of my '80 motor that last worked fine (several months ago)
-The rest of the motor came from a '79 parts motor I picked up. At least the po said it was a '79.
-I did replace the 5 gear with mikes overdrive gear.
-From what I read I did not need to replace both of the 5th gears.
-With the bike on a stand, I can shift into first, and by hand turn the clutch hub (simulating the motor turning it) and it feels smooth and turns the rear wheel just fine.
-With a helper I'm able to keep turning the clutch hub by hand and shift thru all gears, noting they all feel smooth and turn the rear wheel as I would expect, I can even feel the difference between each gear as the ratio changes. They all feel smooth, nothing locking up, no metal to metal noises, no grinding. (that I can hear or feel)
Does this sound like something that could be cause by just the clutch?
It really didn't feel like it was just slipping...It was like a shutter, it felt like it wanted to go, but something was stopping it, but not stopping the motor from turning as it kept running.
I did read thru inxs's clutch thread, and I do believe to have all of the thrust washers/bearings/washers in their respective places.
As always, any help is much appreciated
Thanks
Thanks
