ok that very helpful indeed.
It seems likely that the clutch assembly has been made up of mismatched pieces which is not going to help the situation so we need to look at the individual clutch components and measure them carefully.
I would also suggest that since the PO rebuilt the bike the gearbox has never worked properly and this could be due to incorrect assembly.
regarding the clutch pushrod assembly it sounds like you have got that correct .
Whilst you have the clutch off I would suggest that you check that you can get all the gears by turning the star on the end of the gear selector drum. You may need to temporarily remove the selector rod and use a pair of pliers on the star.
You may need to rock the bike back and forward a few inches whilst you turn the star.
I understand from your videos that you removed and reassembled the selector star so this is worthwhile to check. My gears were difficult to select initially because one of the locking split pins on the selector forks was fouling on an adjacent fork.
