anybody here have this lift? am seriously thinking of getting one. Would make a decent table to work on the engine, once I have it out, too. In fact I bet it could be used as an overhead upward pulling device to help pull the engine up out of the frame, before being shifted over to another platform.
Only thing is, with my relatively low hanging pipes, I'd have to make an adapter of some kind so the frame would contact the lift before the pipes.
Was wondering if any of you all have this one. Right now I have a 20% off coupon, and a birthday coming up.
http://www.harborfreight.com/high-position-motorcycle-lift-99887.html
PS: while I'm at it I'll add a couple of pluses and minuses from HF. Bad = a reciprocating saw I bought there a long time ago. It's decent for wood, I suppose, but useless for metal (which is what I wanted it for) Could be their newer ones are better. Also in the minus column, that multi-tool that they always advertise at $29, it's like a shaper sander with a triangular shaped head. Mine died right away. Oh one more bad thing, an air grinder...cheap thing - I believe it was $10. I bought for use in tight spaces where I can't get the 4.5 angle grinder into. It needs way too much air to really be able to grab. The discs would fall off or break. Let's put it this way, my old Dremel with reinforced cutting discs proved MUCH more capable for tight work.
In the
plus column, a set of deep metric sockets I bought. Awesome! and I believe the 3/8 torque wrench I have from there is just fine, as well. Also, a wrench set of the type used to tighten the steering neck rings - cheap and works great.
