1. Dismiss Notice
    Dismiss Notice
Crabby's Build
Discussion in 'The Garage' started by CrabbyCustoms, Jan 7, 2020.
  1. CrabbyCustoms
    CrabbyCustoms XS650 Enthusiast XS650.com Supporter
    Hi There!
    I've just recently purchased a 1978 XS650 parts bike, as well as a 1978 frame with a wassell gas tank, rear fender with sissy and a set of Panzer handle bars. I also purchased a 1976 "rebuilt" engine.
    I'm very excited to have found this forum as this will be my first bike build and i'm sure the site will be extremely helpful.
    I'm working in a fairly cramped space but after spending the last week tearing down the parts bike I think it's going to work out fine. The tearing down of the parts bike was fairly easy, one thing that I will need to figure out is that the frame i'm using is a rear disc brake set up and i'm hoping to use a rear drum wheel so I need to start searching how to do the conversion.
    I also think I have an issue with the "rebuilt" engine as I took of the valve covers and noticed rust on the rocker arms and rust on the cam. The engine looked so clean when I bought it that I didn't really check it over. Maybe it was rebuilt but then not stored properly?. I have the engine from the parts bike so i'm guessing I could use the cam from it?
    I'm hoping to have a rolling chasis done this week and then have to figure out what the next step is?
    I'm super excited and my goal is to have it finished in time for the CVMG Rally in Paris Ontario in June.
    Thanks! January 13, 2015-29.jpg December 09, 2019-7.jpg December 13, 2019-59.jpg January 01, 2015-1068.jpg December 23, 2019-15.jpg November 30, 2019-30.jpg
  2. Jim
    Is the spare frame a drum brake bike? If so, all the parts should swap.
    Mailman, Machine and CrabbyCustoms like this.
  3. CrabbyCustoms
    The spare frame has been shaved down by the p.o., he gave it to me with cast wheels that had discs on them but i'm going to use the wire wheels from the parts bike. All of the hook ups for the drum brakes that are on the parts bike have been removed on the spare frame.
    Jim and Machine like this.
  4. 59Tebo
    59Tebo 59Tebo Top Contributor
    Wait...what? You need to show us a good side view of the rear of your bike. Does it have a mag wheel/disc brake setup in the back? Your extra frame's serial number will tell you if it's a "Standard" or a "Special" (originally spokes/drum or mag/disc). I'd go over that motor carefully also. Just from your pictures, it looks like maybe the (dreaded) P.O. spray-painted the lower case to "clean it up". Looks like all the seals and the stator cover were painted.
    Uh, and unless you took them out, your points are missing..... :doh:
    P.S. I was a little late with this post... Can you post a good pic of that spare frame? If your going "bob", I'd like to see it...:thumbsup:
    CrabbyCustoms and Jim like this.
  5. halfmile
    halfmile XS Builder XS650.com Supporter Top Contributor
    1,318
    4,508
    263
    kansas
    Can`t really tell from the pics but the bare frame doesn`t appear to have the MC mounting bungs welded on it. Everything will interchange if they`re both 78 frames. Do they have titles? (the most important part of any build). All the info you`ll ever need is here on this site. Good luck with your build.:thumbsup:
    Also are the spoke wheels steel or alloy?
  6. Machine
    Machine Race the wind Top Contributor
    Nice to see a fresh XS project ! Keep the pics coming for us
    :D
  7. Raymond
    Raymond XS650 rider & fettler XS650.com Supporter Top Contributor
    Lots of questions there Crabby and you sure sound super excited. Unfortunately, restoring a forty year-old bike is not going to be totally straightforward and there will be obstacles to overcome as I think you already anticipate. But having most of two bikes is a good starting place and you have definitely come to the right place for the advice you will need.
  8. 59Tebo
    Where are my manners, Crabby? :doh: Welcome to the party! Yes! The greatest site on earth for the Xs, with more information than you could shake a stick at (if that's your idea of a good time). Take lots of pictures, and update often (we're nosy! :wink2:)
  9. fredintoon
    Hi Crabby and welcome,
    first; "everything takes longer and costs more" but you already know that, eh?
    Swapping disk rear to drum rear is easy as long as you have all the wheel & brake parts.
    Just make and weld a drum brake torque stay bracket onto the disk brake swingarm.
    MaxPete and CrabbyCustoms like this.
  10. halfmile
    1,318
    4,508
    263
    kansas
    Just thinking about your brake swap. It doesn`t matter what your 78 frames are, just remove the entire swingarm assy from the drum brake parts bike and install it and the brake pivot in the other frame. one bolt and your done.:shrug:
    MaxPete, lakeview and CrabbyCustoms like this.
  11. CrabbyCustoms
    I just checked the serial number for the extra frame it says it's a XS-SE Model. I took a few photos. The first photos are of the extra frame.
    I just checked the serial number for the extra frame it says it's a XS-SE Model. I took a few photos. The first 4 photos are of the extra frame. Part of the problem is that the swing arm has been set upside down to accomodate the brat kit/fender install so the drum brake arm's hook up is on top of the swingarm.
    The next 3 photos are of the parts frame that the drum brake came off of. The last photo is of cast wheels that I'm not using, I assume they came off of the extra frame? January 07, 2020-11.jpg January 07, 2020-12.jpg January 07, 2020-13.jpg January 07, 2020-16.jpg January 07, 2020-19.jpg December 20, 2019-1892.jpg January 07, 2020-1.jpg
    MaxPete and LanzSilva like this.
  12. CrabbyCustoms
    I do have all of the drum brake parts so I just have to add one of these to the swing arm? December 23, 2019-24.jpg
    MaxPete, LanzSilva and Machine like this.
  13. CrabbyCustoms
    Unfortunately the swingarm has been modified to accomodate the brat kit and rear fender.
    LanzSilva likes this.
  14. Crabby. Welcome to the forum. The spare frame goes with the cast wheels/disk brakes. The rear brake master cylinder bungs are on the spare frame.
  15. The brackets on the top of the swing arm with the fender welded to it are for the disk brake.
  16. 1980 Special cylinder bungs and swing arm...
  17. CrabbyCustoms
    Thanks Peterg, Yes I figured that the cast wheels were meant for the final build frame but I wanted to have spoke wheels and I liked the look of the old school Drum brake. Do you think it's possible? can I cut off the brackets for the disc brake? Thanks!
    MaxPete likes this.
  18. CrabbyCustoms
    Hey Halfmile, I only have a title for the extra frame, no title for the parts bike:( I'm not sure if the wheels are steel or alloy?
    MaxPete likes this.
  19. Jim
    Here's what you need (and already have) for the drum brake.
    Just clean up this swingarm and use it.
  20. halfmile
    1,318
    4,508
    263
    kansas
    The MC mounting bungs are easily removable. Just cut them off and grind them flat then "V" around the edges of the bung and weld them up. you can then metal finish them without any bondo.:thumbsup:
    MaxPete, LanzSilva, MrBultaco and 4 others like this.
Share This Page
